supercub's avatar
supercub
Generator changes speed, what's going on?
My 04 Revolution has a 7500 Watt Onan Generator. When operating the generator and running the TV, direct tv box, refrigerator and 2 interior lights, and behind the scene equipment, the generator will vary it's running speed and associated noise level. As it changes speeds, the battery stage indicator lights on the Xantrex indicator will change from full battery, to low, to med, and continue this sequence as the speed of the generator changes. It will run on each stage for several minutes, and then shift to the next, with no apparent change in power being used. It continues this cycle the whole time I'm running the generator, over and over. I also get an overheating light on occasionally.
What is causing the generator to keep changing speeds?
What is causing the overtemp light to come on?
Thanks
  • You have an inverter type generator, it varies speed depending on the load. It's working as designed.
