DSDP_Don
Nov 17, 2017Explorer
I would do as Kevin suggested or you could reinforce the current mounts by mounting a tin plate over the wood support. Screw the tin plate on into areas of good wood and then use your original screws to screw back into the tin plate.
You could also enlarge the area where the screws goes with a wood bit to about 3/4" or 1", fill with a repair material like resin or hard as nails, allow to dry and then reinstall screws.
38,769 PostsLatest Activity: Jun 25, 2013
