Gjac
Aug 07, 2016Explorer III
I had a slight leak in my fuel line going into carb. I took me awhile to see the problem but it turned out to be a crack in the flare at the end of the tube. I had to cut off the cracked end and reflare it to get it to seal again. Another time when I removed the cover of the genset to replace a coil I found nests of dried grass and acorns packed under the cover. Both of these could have started a fire and were not obvious.
