Grit_dog
Dec 19, 2019Trailblazer
For the geographically challenged, the OP said they're vacationing in the YUKON. Long ways from US gas prices.
To the OP, couple-3 hours of generator a day goes a LONG ways if you don't need AC, which you won't. I'd be surprised if you need to put more than 20-25 hours tops on it in a couple weeks. You'll WANT to turn it off, onboard generators in low end RVs are annoying when you're in the Rv.
You can use the heat as much as you need. You won't need "that" much in June.
Seriously generator gas will be about the least expensive component of the trip save for liver n onions. That costs $0 cause I hate liver n onions. Bait n tackle will cost more than genny gas.
You will want to dump your black tank probably once in the middle of 11 days unless you don't use it much.
Black tanks have a way of getting ripe if they're pretty full and you take a little bouncy trip down a frost heaved road.
Most importantly, sounds like an awesome trip!
Have fun!
Have fun!
38,782 PostsLatest Activity: Sep 10, 2026
