Hotwheelbill
Jan 20, 2017Explorer
time2roll wrote:Hotwheelbill wrote:Yes.
When no shore or generator power, everything that should work then is working, so that would mean that the inverter side is working right??
Need to verify if the inverter/charger is getting power from generator.
Could easily be wired: Utility ---> Inverter ---> Generator ---> breaker panel.
Needs to be: Utility ---> Generator ---> Inverter ---> Breaker panel
I would not even know where to start with that one.
I have two cables coming out of the inverter/charger. White goes into the top of my fuse panel and the red goes in under and into as pictures show.
