mowermech
Jan 21, 2017Explorer II
MrWizard wrote:
120v from shore or generator to transfer switch
From TS to breaker panel
From panel to converter
There are two possibilities that I can think of
Somebody wired the converter in front of the TS directly on the shore input
Or
Your converter electronics do not like the generator output wave form, and is refusing to turn on
This is the much more likely possibility
IMO, this is likely the problem. Have the generator tuned up and checked for voltage and frequency. The output of the generator should be 115 (110 to 120) volts @ 60 Hertz (cycles). If it is an "inverter generator", the wave form should be at least modified sine wave, preferably pure sine wave. These tests require calibrated special equipment that the average RVer does not have.
If you have it tested, be sure to ask when the equipment was last checked for proper calibration.
38,782 PostsLatest Activity: Sep 10, 2026
