Rick_Jay
May 18, 2015Explorer II
willald wrote:
One downside to doing this that I really hate: Like already said, genny cuts off when you get down to only 1/3 or 1/4 of a fuel tank. This limits how far we can go before refueling in the summer.
Absolutely true for our rig as well.
For this issue, I'm currently doing some work on ours and have the gas tank out. I'm going to extend the generator fuel pickup tube another couple of inches. This should allow the generator to run down to the 1/8 tank level. I never let it get down that low, but we've been "inconvenienced" a few times when it would cut out with the current pickup tube length.
willald wrote:
Oh, one other thing I've learned with our Onan genny about running it when on the road: It will shut off if you make a very sudden movement, like a 'panic' stop, sudden swerve/turn, etc. I think its the low oil switch that kicks it off in a sudden movement, as too much oil sloshes away from the sensor. I've tried putting a little more oil in, doesn't seem to matter. It rarely happens and takes almost a 'panic' type movement to cause this, but it is something to be aware of. Not a big deal, if I see after such a movement that the generator has shut off, I just reach over on the dash and hit the 'start' button to re-start it.
This too was a problem for us, and I concur that it is related to the low oil level switch. When we were having the problem I was using 5W30 oil in the generator as I could use it year round. However, I switched to straight 30 weight oil (per the manual) for the warmer months and this problem seems to have been eliminated. Well, I haven't noticed it since switching oils. But if we use the rig in late Fall, Winter or early Spring, I have to change the oil to the 5W30 for the colder temperature operation. (What tipped me off about this is that I never experienced the problem during the colder months, only during the summer and usually hot summer days were the most likely for the situation to occur. And even though 5W30 is supposed to act like a straight 30 weight oil at higher temperatures, apparently it doesn't.)
To the OP...as all are saying, it's perfectly fine to run the generator while cruising down the road.
~Rick
