holstein13
May 20, 2015Explorer II
nemo45 wrote:That's an odd question, but in case you are sincere, I can tell you that I have a 210 Amp alternator (over 2,500 watts) that charges my 16 batteries while I'm under way. I have two inverters, one for the Kitchen A/C and refrigerator and one for the rest of the coach. When I'm traveling down the road with the generator off or if I'm boondocking with the generator off, I can run my Kitchen A/C off of the batteries. If the engine is turned on, the batteries will charge from the alternator. I also have solar panels to help charge the batteries, but, as you probably know, they don't produce enough power to keep the batteries charged after running the A/C for any length of time.holstein13 wrote:
You need to exercise your generator under load anyway. What better time than on a long hot drive?
I find that we often go from full hookup to full hookup; therefore, if we want to exercise our generator, we need to do it while hooked up (waste of fuel) or while driving. I'd rather run it while driving because it takes a load off of my alternator. In your case, your alternator is probably not powering the A/C, but at least you won't waste the fuel exercising the generator while you are hooked up.
Ideally, of course, you'd boondock at least once a month and exercise it there. That way you don't waste any fuel at all.
What makes you think that YOUR alternator is running your roof a/c? Only the thermostat is operated on 12V on the roof a/c. What load is the 110V generator going to take off your 12V alternator? Plus running your generator every time you travel is a waste of fuel if you do it more than once a month for an hour. We are full timers and stay in one spot sometimes for as much as 5 mos. so we have to exercise our generator monthly.
The ability to run the A/C off of batteries is a great feature of this coach. It means that while I'm boondocking, I can go to sleep with the generator off and the A/C will continue to run. With the autostart on the generator, I need not worry about draining the batteries either because the generator will kick on to recharge them at a certain voltage.
And finally, no, I don't run the generator every time I travel. In fact, I rarely run it while I travel. I only run it if I need to exercise the generator anyway.
On edit: I have a 270 amp. Leece-Neville Alternator, not a 210 amp as I specified above.
