rgatijnet1
Sep 22, 2015Explorer III
supercub wrote:
I'll have to look, but if memory serves me correctly, I only have one breaker on the generator. When it tripped, I lost all AC power in the motor home. Both Air Conditioners and convective oven loss power.
You probably only have ONE breaker but it is a double pole breaker which means that it has two separate legs of 120 volts running through it. This means that if EITHER leg of the 120 volts draws too many amps, the entire breaker will trip shutting off all output voltage to both legs.
38,783 PostsLatest Activity: Sep 22, 2026
