Handbasket
Mar 08, 2014Explorer
You've probably got an Onan 2800? Mounted above the floor in the 1st gen 210's, rather than underhung like a 190 IIRC?
Here's a pic of the Onan 2800 in an '08 Tiger a'building, before the coach is married:
This should be like yours. I don't think they've changed it. The connections are on the left side to the back as you look at the access door. In order from left to right in the pic, fuel line, 12V for starter, remote start switch wiring harness, and 120V output lines. You'll probably have to unbolt it, slide it part way out, and reach in over the top to get to the connections. Be sure the battery is disconnected.
The box is probably held down by 4 bolts thru the floor into weld nuts inside the bottom of the box. To get mine out of the Tiger, I had to remove the trim strip around the door to get to the door frame screws, and remove the entire door & frame. Not sure how RT did it on the 210. Easiest to build a platform that can sit right outside the compartment to move it onto. IIRC, it weighs about 125 lbs. One man can move it; I used ramps to slide mine down out of the Tiger.
I'd suggest getting the installation manual from Onan. It'll tell you how much clearance is required for safe cooling. Add some sound deadening if possible (1" rigid fiberglass insulation can be sourced from heating supply places). I cut .2" sheet rubber 'washers' for mine to sit on, and used blue Loctite on the bolts so they didn't have to be but just snug; this'll cut some vibration. Don't block the cooling air entrance or exit (around the exhaust pipe).
You probably have room to add the Onan resonator in the tailpipe. Make sure the outer end of the tailpipe isn't rigidly restrained. It needs to be able to shake a bit to allow the Onan vibration isolation to work.
Good luck with it! BTW, I think the extra length is OEM GM, not added by RT. I've seen maybe two older G-30's as plain vans that I think were that long.
Jim, "Old age comes at a bad time, but it beats the alternatives."
38,782 PostsLatest Activity: Aug 31, 2026
