dodge guy wrote:
I’m thinking I know the answer but still have to look at the owners manual. Just got back from our first trip. Cummins Onan 5500 gas generator. The trip there was no problem. Generator ran fine the entire 7 hours it was on. On the way home it shut off 2 hours into the trip, I noticed when it started to get warm inside. Started it back up and it took a couple times but it started. Ran for about 45 minutes then died again. It was 90 degrees on the way home. The trip there wasn’t as warm and it rained for the first 2 hours. I’m thinking it got hot and shut down. When I got home I checked the oil level and it was full. I ran it for 2 hours in the driveway and it ran fine.
So a couple thing I think it could be.
it got hot and shut down to protect itself.
The fuel was boiling due to the heat.
Or what I actually did find was the altitude setting was at zero feet. We are around 900 feet where we live. Is it possible being at zero in high temps would cause it to shut down? I know it’s a long shot but it’s the only thing I found.
Im still leaning towards vapor lock.
Thanks!
As long as it'clean with the intake air and such, I'd be looking for an oil overtemp switch. I finally disconnected ours on our old Generac and ran it that way for years.
