Well I’m not sure if I have found the issue or not yet. It seems the majority of issues of dying are from oil level and/or pressure issues. I did check all the wiring to and from the generator. All looks good. No loose connections, grounds or power wires. I checked the oil after it was hot and it was about 1/2 qt low, should be at the full mark when hot and that’s where I set it last year. I didn’t run the generator coming home as it was 70 outside and didn’t need it. So I topped it off and I’ll see how it does during our gulf coast trip in mid July! After I fixed the oil level issue last year it ran fine. So I’m hoping it being low was the issue.
We will see.
Thanks for all the advice and ideas. It was much appreciated.
