rivercity22
Nov 25, 2013Explorer
Generator Question
My 2011 Jayco Greyhawk generator starts right up if it only sits for a day or so but takes a really long time to get started after sitting for a few days. Is this normal?
Matt_Colie wrote:
Is the APU an Onan Microquiet?
If so, it may be a fuel drain-back problem.
This is not uncommon, and there is a cure.
If you hold the stop side of the switch with it not running, this enables a "prime" circuit that will run the fuel pump to bring fuel back to the unit. It usually needs to get held for 10~15 seconds.
Try that.
Matt
