two_travelers
May 05, 2020Explorer
Generator questions
We have a 2015 Winnebago Vista. When the generator is not used for some time, like during the winter when it's used once a month, I have a problem. When I push the start button it sounds almost like it takes a bit to turn over. Sounds like a weak battery or stuck cylinder for the first crank. After that first one it has normal cranking sounds. If I start it later the same day or the next, it starts and sounds normal. Any idea what the cause of this might be?
What battery is used to start the generator, coach or chassis?
Batteries are about 5yrs old and are on charge when not being used. What's the typical life of the coach and chassis batteries?
