My generator on my 1989 Southwind is not working. It dies as soon as you release start button. New control board and oil change and it still doesn't work. Now it looks like it is ether oil pressure sw...
Check the fuel line. Mine would start and run for a minite or two, then stop. Turned out the fuel line was cracked, sucking air instead of gas. Ethanol. I got lucky...was able to replace fuel line without dropping the gas tank. Problem solved.
