My generator on my 1989 Southwind is not working. It dies as soon as you release start button. New control board and oil change and it still doesn't work. Now it looks like it is ether oil pressure sw...
Before disassembly, take photo's of all things as they are now. This reference photo will help when you reinstall the genset. Check to be sure your mounting system will allow the genset to hinge down for access. If not, R&R the fuel line and wiring connections, remove 4 mounting bolts and lift out. Good luck.
