time2roll
Oct 04, 2017Nomad
supercub wrote:Sounds normal. I suspect the indicator is telling the charging stage of bulk, absorption, and float. Depending on equipment the generator load could be 18 amps down to 2 amps as the battery charges and the system changes voltage. Yes it may indicate a growing issue with the battery such that it was not noticed before. Or the battery was a bit lower on charge this time.
The Battery State displays 3 different battery levels. First indicator is an outline of a battery and shows a low level, next little battery shows a 1/2 level and the 3rd battery display shows a full battery.
When the generator changes rpm (power) the Battery State display will change also.
I don't recall my generator doing this before.
