wolfe10
Oct 04, 2017Explorer
KD4UPL wrote:wolfe10 wrote:rgatijnet1 wrote:
The sound of the generator will change as the load increases or decreases but the RPM's are what determines the 60 cycle AC output. The RPM's should remain constant, with a small jump as the load changes.
No, not for this particular generator. RPM DOES vary with load.
Which "particular" generator is this? There are Onan diesel generators that do very their RPM. I don't know if the OP has one of these or not and apparently he doesn't know either.
OP, Do you have the exact model number of the generator? Some are supposed to very the RPM and some not.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiwtYnOs9jWAhUX3YMKHY9ECbkQFgg5MAM&url=http%3A%2F%2Fwww.rvtechlibrary.com%2Fgenerator%2FOnan7500specsheet.pdf&usg=AOvVaw02d-yNehLNPBLlkMFtrqyb
From that Onan pdf:
Computer-Controlled Variable Speed Operation Matches Engine Speed to Load Demand, Minimizing Noise Level
