jerseyjim
Jul 08, 2014Explorer
Low voltage from the generator? I don't have an ONAN...but do have a 5500 GENERAC, and the owners manual shows a board with an adjustable screw...for voltage.
Once you read the voltage at a suspected outlet, you can, as I did, have a friend inside watching the voltmeter...and you on the outside turning that adjusting screw...both of you connected by cell phone...when the voltage goes up to where it should be...your problem may be solved. Mine was.
g'luck!
g'luck!
38,766 PostsLatest Activity: Jan 10, 2026
