Jackie_Treehorn
Jul 08, 2014Explorer
tropical36 wrote:I'm heading to the Onan website to see if there is an adjustment I can make to bring that voltage down towards 110. It will also be a good time to find out how many hours I should be running it between servicing it-
I like about 125vac at no load so I can hope to maintain a reasonable level when at full load. I think 120v is optimum and hopefully it never drops below 115v, but that's just wishful thinking in a lot of cases.
With some if not all generac gensets, there's a LED on the voltage regulator board, along with the adjustment screw and I drilled a hole in the cover so that I can see it, as it doesn't always have an output and requires restarting. Just saying, in case you feel the need to see this light as well.
That's interesting- no load I'm at 116 to 117 volts at each outlet but once loaded with one or both AC units the voltage goes up to 118. You're saying you wouldn't think the source of the heat for devices using the outlets is the 118 volts?
38,766 PostsLatest Activity: Jan 10, 2026
