jhilley
Jul 10, 2014Explorer
I don't think you have any thing to worry about with your generator. Just change the oil and fuel filter and you should be good to go. As long as it maintains 118 volts under load it is fine. Depending on your volt meter, the accuracy might be between .2% and 5%. Even a high quality .2% accuracy meter is 2.4 volts AC.
38,766 PostsLatest Activity: Jan 10, 2026
