wildmanbaker
Jul 10, 2014Explorer
As others have said, you should be OK at 118 volts. If you have a microwave with a digital clock, start the generator, set the clock, and check how close it is to your watch, or clock for 10 minutes. If it is running fast or slow, load the generator with an AC and check again. If it is within a minute or two, your hertz are close enough to not cause problems.
38,766 PostsLatest Activity: Jan 10, 2026
