Geocritter's avatar
Geocritter
Generator won't stay running
My 1994 Holiday Rambler is equipped with a 7,000 watt Onan gasoline powered generator. The generator currently has just over 1,100 hours on it. The generator starts and runs fine as long as you keep the starter button depressed (fortunately the starter disengages from the flywheel upon startup) the minute you remove pressure from the starter button it shuts down. It’s the same whether it’s started from the dash or at the generator itself. I've checked the oil and it has a full crankcase, I also replaced both spark plugs. Does anyone have an idea as to what’s going on with it?
Steve
