ScottG
Jul 18, 2017Nomad
aaron o. wrote:ScottG wrote:
For some reason, your not getting the surge current you need from your Onan. Could be the gen but also could be a bad connection, damaged wire or resistance in the transfer switch or, someplace else.
I bet if you could bypass all the wiring from the gen to the AC, it would work fine.
I could try that with the front ac, not sure if I have enough to reach the rear, but that's a good idea also. Thanks.
I agree I'm getting resistance somewhere, but why would the Honda run it fine through all the same wiring after the switch?
Another thought... Would house battery condition have any affect on this?
Perhaps it's before the switch.
Not sure if a low house battery would cause the issue. If it was discharged and the converter had to go into bulk charge mode it could cause problems but I cant imagine the gen being that borderline.
