EV2
Dec 11, 2016Explorer
Bill.Satellite wrote:
"In theory" the synthetics says you get longer oil change periods as the only real advantage.
Actually the major advantage is that true synthetic begins to break down at a much higher temperature. There fore it is superior in any application that has high temps. It is also claimed that it is superior in remaining on surfaces prior to startup. Most high performance engines with close tolerances require it for warranty and the Mercedes diesels even require their specs for warranty. It also is superior for lubrication when condensation may accumulate.
It is an excellent choice for any engine that may sit for periods of inactivity.
