10forty2
May 31, 2016Explorer
Put a fan in the compartment or under it to blow across the genset and that should circulate enough air to keep it below the high temp shut down. If it continues to be a problem, then you might want to add a more permanent fan that is wired to come on automatically whenever you run the genset.
