timmac
Jun 10, 2016Explorer
filadelfia wrote:wildmanbaker wrote:
Tim, you may want to check the fuel system on the gen, as this sounds like it may be vapor locking. A partially plugged fuel filter, or weak pump.
X2 seems like you would be getting an overheating trouble code if the engine was shutting-down on hi temp.
Good luck Don
Than maybe it is a vapor lock from to much heat buildup, I am getting no blinking light on switch after it shuts it self down, so fixing the heat issue is 1st than on to fuel filter and such and I should be OK..
38,782 PostsLatest Activity: Sep 10, 2026
