bobpie
Mar 06, 2017Explorer
I guess you mean that after holding the start switch down for 15-20 seconds the genny finally started?
The light on the start button flashes as the generator is cranking!
It stays solid when running!
If you use the start button on the genny itself, you should press and hold it to prime the carb, and then press it the other way after 20 or so seconds to start. Good luck11
38,766 PostsLatest Activity: Jan 10, 2026
