turbojimmyExplorerNov 02, 2014Getting antifreeze into the hot water sideHere's what I've got: That valve at the bottom shuts off the cold water feed to the HW tank. I had assumed since it had another line hooked up to it, that it would pressurize the hot water si...Show More
Dakota98ExplorerNov 02, 2014Apparently, the original check valve in the HW outlet had gone bad & instead of replacing it, a valve was used in its place.
Related ContentAntifreeze NOT Bypassing Water HeaterWater PumpRV AntifreezeHow did antifreeze get in fresh water tank?!?!?!?!Diluted RV Antifreeze
