Hi gerrym! YES - we have had to shop around to find a service center capable of handling the size or weight of our Roadtrek. No issue at our home base - I use a local Chevy dealer - they put it on the alignment rack to lift it - you need to be careful regarding the TYPE of lift a repair center may have - bars that swing in from the side could crush the skirting before they even touch the frame. Our issues have been while on the road. Chevy dealer in Anchorage, AK couldn't handle the weight, but the Midas dealer was great. Chevy dealer in Park City, UT, didn't have the height to lift it. So you just need to check around. For oil changes on the road we use Jiffy - Lube - type places, since no lift is required - they are designed with drive-on bays and the service is performed from below. Never had an issue due to the fact it had propane on board - really no more dangerous than the 30 gallons of gasoline it carries! ST
