draboo wrote:
We had a set of tires put on our MH and I noticed that the front brakes had seized up. I called a local shop and they recommended a different shop 60 miles away. After further investigation,it was found that our rear brakes had not been working because of the ABS module was bad. Kaiser Brake and Alignment in Eugene,OR let us stay almost a week in the parking lot while awaiting for the warrenty company and the part.We had a 50A service to hook to and a dump station right at the shop.Today, I drove the MH home tonight and the brakes worked fantastic.
If anyone needs work done in the central Oregon area, I highly recommend them. They also stock heavy duty trailing arms for the Monaco/Holiday Rambler units that were under recall.
Thank you, Mel and crew!
Great to hear positive news about a service provider.
I would like to know more about how a bad ABS module would prevent the rear brakes from working? Do you have air brakes, or standard hydraulic brakes? Did they offer any explanation as to how that works? As far as I always knew, even you have a problem with the ABS system, the brake system should still function - without the benefit of ABS braking. Then again, I'm no expert, which is why I'm asking.
