dougrainer
Aug 08, 2015Nomad
You have made the smart choice. When NEW, the BIRD systems are OK, but if you have to replace because it fails to charge the chassis battery bank, go to a stand alone trickle charger system. BTW, you should also understand that on your year Newmar and up to at least 2008, the Genset is started by the chassis battery bank on Diesel pushers. The downside to that is this---It takes 12 volt source/power to run the Genset after it is running. So, if you are running more than 6 to 8 hours and the BIRD is NOT charging the Chassis batteries, the Genset will drain the chassis batteries and when they get below 10.5 volts the Genset then dies because there is no 12 volt power. Doug
38,763 PostsLatest Activity: Dec 05, 2025
