kyclassa's avatar
kyclassa
Going from Motor Home 50amp to house 20amp
I bought everything I need to go from my 50amp on Motor Home down to the 20amp GFI on the outside of the house. But when I hook up with power off on camper, the GFI keeps kicking out and it does not matter which end I hook up first. What else can I do without going to a 50amp plug in? Appreciate any help. thanks
  • I Had he same thing happen and nothing helped until I swapped out the GFI or a regular outlet. Now I have a 50 A receptecal.
    It almost seemed like my garage GFI didn't like the GFI's in the MH or the inverter, or the transfer switch, or ???. I had the coach checked thoroughly for any problems and it was proclaimed perfect so there is something else going on that no one could explain very well.
  • All the exterior outlets on my house are GFCI as well. Are you sure yours is actually 20 amp? They might be 15 amp. At any rate when I used to plug my 50 amp hookup with the step down connections to a 15 amp GFCI, it would always trip the GFCI. So, I just wired my own 50 amp plug directly to my outside breaker panel. This is the best way to do it.
  • kyclassa wrote:
    I even plugged it in the house without a GFI and it sparked and would not take it. Never been to a park let and plugged into a 50amp.
    This scares me. Get an electrician involved.
    Until I read this post, I thought you just had a GROUND/NEUTRAL connection somewhere in the RV.
  • Check to make sure the male and female extentsion (inside the plug)wiring is secure and have good contact with the screws.
  • I even plugged it in the house without a GFI and it sparked and would not take it. Never been to a park let and plugged into a 50amp.
  • obgraham wrote:
    What happens if you plug something else with a pretty heavy draw, like a portable heater or a hair dryer, into that GFI? Should help you pin down the faulty bit.
    Works just fine. No problems there. Just the RV.
  • ScottG wrote:
    Are you saying the 50 adapter all by itself trips the GFCI? Or is it the RV that trips it?
    The RV even with power off. I have the 50amp cord going down to the heavy duty cord and when it is pluged in the GFI trips.
  • What happens if you plug something else with a pretty heavy draw, like a portable heater or a hair dryer, into that GFI? Should help you pin down the faulty bit.
  • Are you saying the 50 adapter all by itself trips the GFCI? Or is it the RV that trips it?
  • I go from 50 amp to 20 amp all the time because my RV is stored inside. I plug a 20 amp heavy extension cord directly into my 50 amp RV line with the usual step down connections. Never have had a circuit flip out. Perhaps your 20 amp GFI circuit needs to be replaced.
