centerline
Feb 02, 2018Explorer
the link following shows what I use and is about the best deal you will find for one that is as dependable...
unlike other small compressors, this is a brand name unit, is rated at 100% duty cycle, has a decent cfm rating and will fill the tank with plenty of pressure to air up tires...and has a decent warranty.
after a few uses, the small oiless "budget" units that are so common and cheap, do a poor job of giving enough air to do much more than low pressure atv tires...
https://www.ebay.com/itm/Air-Compressor-Chrome-400-airmaxxx-3-Gallon-Air-Tank-Drain-165-on-200-off-Switch/382215239182?epid=2216948293&hash=item58fdcdb60e:g:w~AAAOSwOgdYzDOS
38,783 PostsLatest Activity: Sep 09, 2026
