MDKMDK
Jun 17, 2023Explorer
If they put it in the Owner's Manual, under towing the vehicle, it's there for a reason.
If it were me, I would pull the fuse, as it's simpler than running a new battery charging line through the 7 pin wiring connector between motorhome and towed. There's no additional wiring, or inline fusing required, as would be for an extra separate battery charging circuit.
However, do whatever you feel comfortable with, since you're probably not under warranty on the Equinox any more, anyway.
Some more brief discussions on removing Fuse 32, or not.
https://www.irv2.com/forums/f85/fuse-32-on-equinox-or-terrain-319950.html
https://www.irv2.com/forums/f85/fuse-32-in-the-equinox-and-terrain-who-needs-it-333497.html
https://www.irv2.com/forums/f101/equinox-fuse-32-a-317746.html
38,778 PostsLatest Activity: Jun 10, 2026
