Hotwheelbill's avatar
Hotwheelbill
Good Bad or Ugly........I'm a Diesel Pusher owner.
I got a phone call from my sells contact at Lazy Days yesterday morning. Bill McVey, had remembered I was looking for a cheap diesel and here is what I got.
1998 Georgie Boy 35'. 330HP Cummins (It is an early 1998 with the manual P7100 injection pump), 6sp Allison, Freight Liner Chassis with 78k miles. They just put a new fuel line and four new rotors, pads and calipers on as well as two new house bats. Interior is worn but very usable and a couple of leak places, but the rubber roof has been recovered not too long ago. Everything works. LP Genny.
It needs tires, shocks and the levelers are chained up with the lights blinking on the dash.
I did not make a killing, but for 15000, I am happy for a starter Pusher.
Picks to come later.
Now for the questions.
Tires for 22.5 Alloys?
Remember, I will have this home for only about 3 yrs by my plans.
Shocks?
I have looked and think Koni is perfered over Bilsteins.
How do I look up what will fit?
  • fcooper wrote:
    When I bought shocks, e shocks had the best price. It's one place to check.
    e shocks
    For tires, I've been very pleased with the Sumitomo's, but I'd also use firestone, bridgestone, continentals, etc....there's many good brands out there.
    If the old tires are good enough to get you home, consider loading like for a trip and getting 4 corner weights to see if the current tire size is adequate. Sometimes one corner is much heavier and the originally spec'd tire on that corner is running right at or beyond its load limit. Since you're about to buy tires, it is the ideal time to correct that situation.
    To get it home without listening to the jacks down warning, you can find and pull the fuse to the jack system.
    Since you have a Freightliner chassis, you can get some great free help when you have chassis problems or questions. Freightliner maintains a helpdesk that will provide assistance at no charge. Have the last 6 digits of your VIN number handy when you call them. The Freightliner help desk phone number is
    1-800-FTL-HELP (1-800-385-4357. I've also purchased parts from them.
    Good luck and have fun with your new motorhome.
    Fred
    Thank you. Good info.
    I have used Eshocks before, but I just don't know what size shocks or how to find out.
    I will drive it home Wed. It will be a long trip to Jax and I dont want to take I75. I may cut up threw the Forest.
    I will not be able to weigh it. What tire range would be safe to just go with?
  • When I bought shocks, e shocks had the best price. It's one place to check.
    e shocks
    Fred
  • I would DEFINATELY check the tires for cracking, date codes, tread wear, etc. UNLESS you are not going to drive it. A blowout at even 30 or 40 MPH can be disastrous for both you and any vehicle or pedestrian nearby. Same for shocks but you already seem to know that. Join FMCA and use the Michelin advantage tire program for both your MH and your car.
    Bob
    Life (and stuff) is what happens while you're making plans!
