Another view:
The GY 670's are one of the BEST tires ever made.
I've had Goodyears on my last two coaches...G670s. They showed very little wear and performed flawlessly. I believe you reap what you sow.
Put 'tires' in the search box above and check out the "opinions" of a lot of folks on here. Many seem to think they know more than the engineers that design and build them.
I've maintained my tires per the manufactures instructions including PSI, balancing etc. It is my belief that because of this, my tires have performed as they were designed. I run G670s on my drive and tag axle with Michelins on the steer. Michelins because Goodyear does not make a 315/80/22.5 tire.
Goodyear and Michelin are the only two manufacturers who specifically make an RV tire. The others are TRUCK tires. I would consider putting truck tires on a truck if I had one, but I have an RV....just sayin....
Good luck with your decision....Dennis
