Daveinet
Aug 20, 2013Explorer
Slowing down only means something if you have a king sized mattress up your exhaust, which includes most stock exhaust systems. Those systems tend to get inefficient at higher speeds. While headers and straight through mufflers may not make much difference at 65 and below, they will keep it from noise diving above that. If you like to travel fast, headers will make a difference.
Second thing is to get a vacuum gauge and learn to use it. Air flow through the engine is mainly a function of vacuum. If air is flowing through, so is the fuel. Using a vacuum gauge gives you a reference to tell you how much fuel you are using. Depending on the wind and your coach, you may discover a small change in speed makes a big difference. Other conditions, you might find you can travel much fast, without sinking the gauge.
One should also note that it may help to get a run on a grade, so you are in the power band. There are many times when speeding up just a little, may prevent it from downshifting, and therefore save fuel.
38,782 PostsLatest Activity: Aug 11, 2021
