- John_S_Explorer IIThis is for our DP bretheren and older ones at that. If you have a bigger engine it works even better. I replaced my muffler with a resonater. Now it was because the muffler got a hole in it and they do not make it any more. The redone exhaust gave me about 50 HP more and I run cooler and between .8 to 1 mpg better fuel miles. Now in one trip I do three times a year, VA to Spokane WA I saved over 173 gallons of fuel over what it was with the stock setup. Many of my fellow Foretravel owners have been doing it too. It seems that Foretravel owners for the most part put on more miles per year than other MH owners. I am over 300K miles since I bought my first Foretravel and I am on my third.
- GoldencrazyExplorerI think some joke about driving less but it is serious. Plan your trips to drive fewer RV miles. Stay longer in one place. Take the direct route. Do scenic drives in the toad. This coupled in with good driving practice like slower speeds and driving like you have no brakes can really improve your fuel cost.
- path1Explorer
got any tips on how to save on gas
Don't burn it. Stay longer at each place. Camping chair gets great MPG - HeisenbergExplorerMy credit card gives 3% rewards on gasoline.
- LaPlayaExplorerI am getting 8 mpg consistently. I set the cruise at 3 mph below the speed limit, I open the vents rather than run the dash air. I have the triton v10 on a 31 ft MH.
- Peg_LegExplorerCheck out gasbuddy.com just before you start your trip. Then use the Gas Price Heat Map and zoom in on the area your traveling. You can check gas or diesel prices. The default is 48 hrs but you can change it to a little as 4 hrs for the latest price. Plan your stops in areas with the lower prices.
- V10guyExplorer32' gasser, with the thirsty 8.1l, its a great motor and plenty of power...I get around 7.5mpg. I avg 60mph on highways.
No additives, regular octane. - peaches_creamExplorer
wny_pat wrote:
I will continue to let others depreciate motorhomes for me before I buy one. That is the only way I can afford to run one.
Deleted - wny_pat1Explorer III will continue to let others depreciate motorhomes for me before I buy one. That is the only way I can afford to run one.
- peaches_creamExplorerDeleted- Did not mean to hi-jack OP post.
38,782 PostsLatest Activity: Sep 10, 2026
