tpi
Jun 24, 2015Explorer
loneryder wrote:
Thanks all. It's a 2015 on a 14 chassis with 2200 miles. The steering always needed correcting. Go around a curve and you had to physically correct the steering. Just staying in a lane required constant steering. That is very tiring after a few hours. Windy conditions were constant work. I haven't weighed the coach but have a good idea of the weight. I use the Michelin guide for tire pressure and am running about 65 right now. I have the rear tires set up with pressure stabilizers/monitors so can monitor the pressures pretty well. The mechanic thought the steering was too tight. That is why he suggested a quarter turn trial adj on the steering box. He said that I should take off the stabilizer before I played with the steering box. It's easy and I could do it while on the trip to try it. If I didn't like it, put it back on. Going to drive it for a while to get used to it.
Are you running the 65 based on weight on front wheels? I do and run 10 pounds less than you are. It makes a difference. I don't think loosening steering will help-actually I think it will make it worse. Tightening it to remove any play would be good. I don't think removing steering stabilizer will help.
Drive it a while once you actually weigh the front end and set pressure accordingly. If after some usage (some of this is just getting used to a top heavy truck) you still think there is a problem my suggestion would be in this order: shock absorbers with more control, and heavier anti roll bars front and rear.
