msmith1199 wrote:
Dutch_12078 wrote:
I don't know how the Tropical plumbing is configured, but my '95 Coachmen has a valve setting that uses the regular pump to suck water from a bucket or jug to fill the water tank, or with a different setting, to suck RV antifreeze from the jug to winterize the water lines. It should be possible to modify the Tropical to do the same thing with a little creative plumbing.
And I have that, but the way it is set up it only sucks water from the bucket and into the plumbing and not into the tank.
If you have the 5-valve WaterWorks panel, suction filling the tank is only one valve position different from the winterizing valve setup.
