msmith1199 wrote:
I don't understand why people have this siphon problem. Once the air pocket gets created at the top of the tank the water should stop coming out of the overflow.
Had this problem with my 2011 vista. The overflow is on the side of the tank, not the top. To fix it I had installed a tee in the overflow line and routed it higher than the tank, this prevented the siphon.
The siphon happens because as the tank fills it bulges out due to the weight of the water. When water comes out the overflow tube on the side of the tank it starts to siphon out as the air pocket is above the overflow tube. It continues and the bulge on the tank now concaves. At the point where it can no longer concave it will then suck in air, then the tank will bulge back out (but not as much as when full) and draw in even more air and the water level will go down. Bad design on and hopefully Winnie has addressed this.
