Gjac wrote:
valhalla360 wrote:
I assume you looked around on the exterior and didn't find a fill hole?
If you don't: You could stop by the hardware store and pick up a garden hose end fitting. It would only take a minute or two to put it on, fill up and then 30 seconds to pull it off. Just have the fitting and a screwdriver handy by the front seat when you pull in.
How do you by pass the check valve to allow water to flow in?
Same way when you use a standard hose at a regular tap. Might be a valve or valves you switch over.
I doubt they put in a fresh water tank and there is no way to fill it.
