crasster wrote:
Sounds like there are some O-rings creating reistance in the shaft that the bar travels, but is no longer connected to the small flap that is pulled away.
I would remove the cap where the bar travels through to see what is going on... You will probably need to replace the handle.
I have no idea what you are describing here. There is no "cap" that can be removed anywhere on the exterior of the valve. Maybe you're referring to a different brand or model? I don't know what brand I have, there is nothing written on the handle...
