camp104
Jul 12, 2015Explorer
Grey water
When camping in full hookups I always keep my grey tank closed until full. When dumping the grey tank it smells worst than the black? Would it be better to keep the tank open or closed?
holstein13 wrote:Executive wrote:X2. This is exactly what I do and I feel Dennis has the correct theory as well.
I leave the grey open and the black closed. Moving day, I close the grey just before our showers. I then empty the black and flush with the shower water. After three flushes, I allow some shower water to fill the black then close it. I then finish draining the grey tank and I'm ready to travel.
My opinion is as you shower, do dishes etc. that water is hot to warm and anything from the shower and/or kitchen sink is still suspended in that water. By allowing it to drain immediately, you're moving those suspended particles into the sewer with the hot water. Same with soap scum. That's hot water being sent thru the sewer hose. By allowing water to sit in your grey tank for days, those suspended particles settle to the bottom of your tank where they mix with any food particles, grease or whatever from your kitchen sink. The water cools and all that mess now gels. When it's time to empty the tank, any clear water must pass over and/or thru that gooey mess before emptying into the sewer. Also, you're now sending cold water thru your hose. Hot water will keep things a lot cleaner than cold water.....Dennis
