tenbear
Dec 27, 2016Explorer
socal77 wrote:tenbear wrote:
I looked at the screws I used. The screws that hold the arm to the block are fairly heavy and go thru the block and into the wall. Nothing special about them, ordinary wood screws with a hex / Phillips head.
I just don't want to go through the wall and have the screw come out through the exterior wall.
Mine had several screws that went into the wall. I removed one and measured it. That was the limit that I would allow screws to go into the wall.
If you remove some of the trim you can see how the wall is constructed and use the appropriate length screws.
The wall in your RV may or may not be the same as the wall in mine.
