mrbrown4christ wrote:
Thank you for the great advice all of you have given me. I spoke with the dealership and plan on going there tomorrow to get the RV weighed BEFORE purchasing it.
Strangely enough I also called Thor (the manufacturer) and gave them the VIN# for the RV, and they said that RV left their factory brand new weighing in at 18,190 pounds. So they said the weight on the Title must be a mistake.
But I will be weighing it tomorrow to make sure before purchasing. Thanks again for your help.
I would be shocked it weights 18,190 lbs dry, and even if it weighed under the 22,000 lbs its still to light of a chassis, Thor should of at least put it on the 24000 lb chassis, the specs say it almost 38 foot long and with 3 slides, full of water, fuel, food, supplies its going to outweigh the 22,000 lb chassis for sure..
