Seabass69 wrote:
Thanks, I was about 26000 empty when I got it but no idea on the loaded weight.  Hitch has a 10000 sticker on it.  The problem is trailer is about 12000....  FYI I have been pulling this for 3 years now just wasn't sure what was legal incase I get stopped....
GCWR in most states has no legal standing.
However, the actual vehicle weight divided by the inches of tire width DOES often have a legal limit, AND the weight on each axle often has a legal limit.
From looking at the tag, the MANUFACTURER says you can tow at least 10,000 lbs.
Can you exceed that limit?  Well, apparently, you HAVE been exceeding it.  Has anything bent or broke?  No?  Oh, well...
The chances of you getting stopped and weighed in an RV are so slim as to be a non-issue.
However, if you have an accident, nobody knows WHAT will happen!
Good luck.
