dougrainer
Oct 14, 2021Nomad
Brandon the Traveler wrote:dougrainer wrote:Fill it with water and let it sit, then flush it out with a wand, and bacflow valve fitting, then buy a 6 pack with the $10 which is a much better use for it. Poop is not concrete. It has completely different properties and can not be used to pour a highway driving surface or a bridge abutment.Brandon the Traveler wrote:dougrainer wrote:
I would shut the tank valve boil as much water as possible and pour that hot water with the rid x. Try to get at least 20 gallons of hot water and let sit for a few days. Hopefully that will break up the poop and get it into suspension to then drain out and flush. Doug
Why not dump 20 gallons of boiling water and a $10 bill down the turlet? The hot water will kill off the bacteria in the rid X, which is @ $10 a box, and even when active without boiling it to death will do nothing in something with a small volume such as an RV HOLDING tank. May as well use the $10 bill and save the cost and time of running out to buy the rid-X.
OK smart #ss. I posted a solution. What is your solution? Doug
I just went thru ALL Rid X operational uses including the FAQ section. There is NOTHING in the Rid X literature that states using hot water will harm or do anything to the Rid X. The Reason I stated Boiling/Hot water is to help melt the solids in the bottom of the holding tank, to allow the Rid X to do a better job. Doug
38,782 PostsLatest Activity: Sep 10, 2026
