Cocky_Camper
Oct 25, 2021Explorer II
If you have time, fill it with water and let it sit. It will eventually soften up. Go for a drive before dumping to make sure loose. Repeat this process a few times.
Ice does nothing unless the water is already close to freezing to keep the ice from melting so fast.
I personally wouldn't dump boiling hot was down my plumbing (home or rv). Being a plumbers son, it could cause damage.
It the toilet drops straight into the black tank, you can try a wand to help the process. It if goes straight down, you can do as my uncle did and stick your broom stick handle down and try to help dislodge (he was warned not to keep his black tank opened).
Good luck! It sounds like a sh!tty job no matter how you look at it! lol
38,782 PostsLatest Activity: Sep 10, 2026
